1 - 6 of 6 Posts
· Pro Flooring Installer
Either way is fine if you are putting down a pad. If glue down, it is easier if the carpet goes first.
If skirtboard and baseboard are the same thing you can go either way. Personally would want to do the skirtboard/baseboard before carpet. You can raise the skirtboard/baseboard a 1/2" which allows the carpet installer to tuck the carpet under for a nice neat appearance and this makes painting easier in the future because you can slide a thin piece of plastic between the skirtboard/baseboard and carpet. If you decide to do the skirtboard/baseboard after the carpet be sure to ask the installer to compensate for this by moving the tack strips an extra 1/2" to 5/8" inch away from the wall. The problem if you do not account for the extra 1/2" it will make replacing the carpet in the future much more difficult because the tack strips will be under or too close to the skirtboard/baseboard.
Rege
Discussion Starter · #6 ·
I have to get your idea befor I started my carpeting.
I have two new rooms , with wooden particle board.
4.3mx3m
and
4.3mx2.5m.
Carpets are available 69$ per meter in 3.6m wide.( NewZealand dollers)
Under lays ae 25$ per meter.
Nailed strips are cost 1.88$ /m
WEhen I totaled it cost me carpets 602$+ underlay 215$ and nailed strips anothre 50$.
total 867$.
Is there any other cost on top of this as a DIY project.
One shop gave me a quotation for 1100$ to 1200$ to do my carpeting.
If I do it as DIY I can save 330$ acording to above figures. Do you think is it worth to do it as DIY project. or better to higher a person to do it for 1200$.
much appreciate your comments.
1 - 6 of 6 Posts
