They have already glued and stapled pad down.Those "bubbles" look to be folds from during delivery, hopefully they accounted for the cut gap against the walls when it flattens out.
Bad, but at 72, I still work part time.You’re an old fart. How are your knees?
They are just too lazy or too cheap to get more help.Even at a heavy weight of 78oz face weight. That has been their argument. The face weight is too heavy in that big of a piece.
Don’t pick HD or Lowe’s or anyone else who wants to be paid in full before installation.Any tips on how to pick a good floor contractor. What are good questions to ask, etc .
Pad has always been used on stairs, at least since I started in 1973.If you keep the pad, you need to pay for it. I didknow that pad was used on stairs ... wouldn’t that be a hazard?
Even with runner-style stair carpet?Pad has always been used on stairs, at least since I started in 1973.
I have only had one house with stairs, my current one. Built about 93. There is a runner of carpet up the stairs, hemmed edges, no pad. The runner is the same material as the first floor carpet. I was just thinking that pad on stairs could be an issue, extra thickness and an opportunity for the carpet to shift.Pad has always been used on stairs, at least since I started in 1973.
It won't shift if it is installed properly. It is hooked on tack strip. And some runners do have a pad under them, normally thinner than regular pad.I have only had one house with stairs, my current one. Built about 93. There is a runner of carpet up the stairs, hemmed edges, no pad. The runner is the same material as the first floor carpet. I was just thinking that pad on stairs could be an issue, extra thickness and an opportunity for the carpet to shift.
You have to be very careful about warranty. Even using the wrong vacuum can void warranty.That’s the only thing worried about. One installer said they have no problem using this pad they will fix it but he said good pad only two weeks old and no reason to rip out perfectly good pad. But your right no mention of warranty.
