1 - 7 of 7 Posts
Hello
I have a wet bar that is roughed in, but has the fitting for the drain line. The main piece is glued on, and the end of screw on. Does anyone know if they make a piece I can just screw on to cap it, or does it need to be cut a solid cap glued on?
If you can’t find the aforementioned cap, try a rubber Fernco cap. Or use my bargain basement method, put a baggie over it and secure it with a zip tie or masking tape. And who cut that hole and left enough annular space around the pipe to drag a dead cat through?
Hello
Yes, any 1 1/2 pipe thread cap.
I would cut it off and put on with a new trap adapter fitting so it closer to the wall.
Could be tricky when you go to plumb the sink in that location.
Hello
stuff a towel or rag into it, it doesn't need to be pretty
or put a plastic bag over it and tape it to the pipe
1 - 7 of 7 Posts
