Looking for some help regarding my Falmouth Cottage, and moisture and dampness coming up via the crawl space or sub basement into my floor rug. I would like to take up the rug and install some Porcelain tile over the plywood subfloor. However, I assume that the tile and grout will crack over the years from the moisture coming up through the plywood flooring. (There is only the plywood sub flooring.) I was thinking of stapling 50ml. Poly to the joists under the house, or should I install insulation--the hard foam board or R-25 type placed in-between the floor joists with wire supports that you mentioned recently? If so, will the insulation stay dry?
I can lay Ploy on the sub basement sand/ground for when it rains--the water will eventually come in from outside and "puddle" on the poly. This is indeed a big Conundrum.
Thanks Jimbotta
:thumbsup:
Thanks Jimbotta
