Hi:
My a/c condenser fan was running but compressor was not and seems the start run cap (370v 20x15 MF) is bad as i can see the top distorted/bulged. the diagram says this cap is wired to the start and main windings also there is a bleeder resistor between two cap terminals (possibly to dicharge cap as a safety ?). The diagram also mentions a fuse probably in-built in cap to protect this device?. I need some advice here: Being a very old A/C I could not locate a replacement of the original cap and a salesperson gave me a dual-run cap which he thinks would work fine. i could use the original resistor across terminal C (line L1) and start winding A (labelled as "Herm") and - here is my problem - main winding would wire to cap terminal labelled as "Fan".
The new cap says 20+15/370 v dual/run capacitor.
Can I get some advice whether something is amiss here before I wire the new cap and destroy more devices or the compressor itself ?
Thanks and Regards.
Thanks and Regards.
