I'm having trouble lowering the temperature on my Honeywell L4103A 1019 Aquastat. I've gotten some help on other forums, including the plumbers forum on DIY, but someone there suggested I try here. I've found this documentation on the aquastat, but as you can see from the picture of mine, it's slightly different and the diagram in the doc doesn't do a great job of labeling the different parts.
I'm not really familiar with the terminology, but from the documentation I understand there is a factory-set setpoint - which is set by the factory and cannot be changed and an adjustable temperature setting scale (also referred to as a setpoint), which is the high temperature at which I would like the burner to shut off. And the solution in this post suggests that I need to set the low temp first and the high temp second, and then let it cycle through a few times.
Here's what I'm still trying to figure out:
- In my photo, is #3 the marker for the lower or high temp?
- What does the little lever (#2) do, is that for the lower or high temp?
- The dial lists both warm/normal/hot as well as what appears to be actual temperatures (although all but one is faded). Which do I use for setting the temperatures that I want?
