Long time reader here, First time poster.
I'm replacing the old tstat (2-wire, oil heat only) with the VisionPro IAQ. I'm having issues with either the wiring / jumper / or the iaq system settings.
I have tried several wiring combination but the result is either:
1. Heat (the boiler) never turns off (even if I set the IAQ system from "heat" to "off")
2. Heat doesn't turn on when the tstat calls for heat.
Here's my setup:
Two wires wired to 'C' & 'W' on module
24VAC wired to 'C' & 'R'
3 wires from module to the 'stat
There is a factory installed jumper on R-RC-RH
Any ideas?
Here's my setup:
Any ideas?
