Hello everyone,
I have recenlty purchased a brand new mini-split a/c, followed installation directions to a "T" but can't seem to get unit to turn on. I have included a picture to show the wiring diagram of the unit(s), all wires are in their correct location for I have checked them countless times now. I have just purchased a multi meter as well as a 400amp clamp style amp meter, both of which I have no experience in using. So hopefully someone can help me trouble shoot this process, in hopes that I dont have a faulty unit.
Some of what I know:
the wire coming from the fuse box is hooked to a double 20amp breaker.
No fuses on the units that I can find.
the previous compressor (outdoor unit) works and still works, so I don't think the problem lies from fuse box to outdoor unit.
all wires used are wires that came with unit (installation kit) 12gauge.
using amp meter with old outdoor unit I get a reading of 7, but nothing with new unit, because it's not turning on and pulling anything I guess.
May be unsafe and silly but I've tested each connection all the way from outdoor unit to indoor unit by shocking MYSELF, thats each single wire: red, black, white all had shocking power to my finger by using the grounding wire on each unit.
The remote is supposed to turn indoor unit on, which then turns outdoor compressor on, but with the remote by pressing power on, I get nothing. the remote lcd screen works so, I don't think its bad batteries, also there is a physical on off switch on the indoor unit, but it also does nothing when pressed.
So, with all that being said I guess my question is how do I use the meters I have to see if the unit(s) are faulty, or how do I get this thing to turn on?
house and unit are 110.
Any help would be greatly appreciated.
