housing holds a mess of wires coming/going from top (overhead light?), bottom (power source?) and one side of the housing ( to feed another outlet other side of wall).
bottom housing: white, black and cooper wires. white wire from bottom and top are tied and capped off. black wire is placed onto right lower black screw. copper wire onto right lower green screw.
top housing: two black (separate) wires and a white wire- one single black wire placed onto left upper bronze screw. other black wire is tied/capped and has two black pigtails- first pigtail going out side housing to another outlet on other side of wall and second pigtail placed onto right top black screw. white wire (tied to bottom white wire- capped off)
side housing: black ( pigtailed to the black wire from the top housing), white wire placed onto lower left silver screw and a copper wire that is not attached to anything.
as it is, the switch works to turn the overhead light on/off. none of the outlets work. tab between right black screws is removed.
i used a voltage vac/dc reader. touching each wire to metal housing and repeated touching each wire to copper metal, i got:
black wire to bronze screw ( left top)- no light.
white wire to silver screw (left bottom)- lite up- hot?
black wire to top right black screw- lite up-hot?
black wire to bottom right black screw- no light
is it confusing enough? is there a way to make it work again?
thanks in advance!
thanks in advance!
