1 - 20 of 22 Posts
I have researched and researched, but it doesnt seem that very many people have had this issue. my house was built late 40's. We have a home warranty plan, and they sent out a pretty lazy plumber. he gave up. we went and rented a plumbing auger which we could not for the life of us, several hours over a couple of days, get the auger to down the correct way of the sewer clean out. i suspect its a tee pipe. is there a tool to help guide it down the right way? i am trying to avoid another plumber, and i dont think my husband wants to pull the toilet up so we can try it from that point.
A plumber had to rent an auger :eek:
These home maintance policy's crack me up.
To remove a toilet is about a 2 min. DIY 101 job.
Premium Member
Moved to the plumbing section-
My first question is- are you sure the blockage is below the cleanout?
he didnt have to rent one (that i know of). my husband went and rented an auger and we failed. but my husband kind of didnt take to the pulling the toilet up idea very well.
Banned
Home Warranty equals guy with a six pack of beer in their car, then tells you to hold the can they just popped open, while making it look like they know what they are doing.
Banned
Hire a real plumber, stop paying on the warranty. You and your husband can do more damage than good if you do not know what you are doing when it comes to old plumbing.
Some of the old waste piping is nothing more than layers of tar paper, that tends to fall apart after twenty or so years in the ground.
Remodel and New Build GC
DJ....
1) I'm sure you've considered it, but is it a no go with chemicals.... or a pressure ____ (bladder).
Best and good luck
Peter
Discussion Starter · #10 ·
the warranty came with the house. and we try to diy. 4 kids, so were trying to get off without having to pay 125/hr.
Premium Member
There are ways to get around the tee, but it's difficult to do- I have watched seasoned plumbers work at it for awhile. I am assuming the tee is faced the right direction...
Your best option is to hire a good small shop to come and open it. If you haven't ran a cable before- it could get dangerous
The blockage is downstream from the clean out so that is where he should start.
Pulling the toilet should be the last resort- but will work too. Best to keep the mess outside.
Premium Member
Pay by the job- not hourly
Discussion Starter · #14 ·
hourly or by the job, id rather try and get it done diy. so that way, future problems can have resolution by us. the clean out drops about 4 feet into the ground, and cannot get the auger to go any further. we used a non power hand forced auger, and we were able to get it to feed about 25-30 feet (give or take a few feet). but the auger isnt going anywhere but to the bottom of the vertical pipe.
Banned
Again, unless you know what you are doing, stop before you do more damage to the existing piping. Who knows what is going on down there. If you have trees in your yard, they are most likely the culprit of the clog, but also it could be due to the waste line has collapsed.
Hire a good shop in your area, not one with the flashiest trucks or largest ad's in the Yellow pages, nor on Angie's List. I only trust two companies in my town when it comes to plumbing. Both are family owned businesses, family's that have been in the business for over 100 years. One is a one man operation, the other is a small five man shop. Both know what they are doing, and I would trust them over the shops with the pretty trucks and expensive tv ads any day.
DJ.... I know those warranties are often a piece of junk... but can't you hold them to it.... and then get to see how it was ultimately fixed.?
I hope you did not have to pay the first guy.
Best
Peter
Discussion Starter · #17 ·
Idk. This is our first home and first experience with having to fix things like this. It did cost 60 bucks, that we paid for absolutely accomplished.
DIY Enthusiast
You or a plumber may be able to run a camera down the pipe to see what's clogging the pipe. They have camera's that will run all the way to the street.
It should be able to show you exactly what your dealing with.
DJ.... Read your warranty contract... now that is no fun... but it's got to be esier than snakeing through a clogged main. Generally, the contract will provide the company make a covered repair, with a deductable ($60 apparently in your case) and should provide who the deductable is to be paid to. You still have a right to have it fixed.
1 - 20 of 22 Posts
