I am trying to install two large outlets into an outdoor box. One GFCI on its own circuit and one switched outlet in the same box. I had to grind along the edges of the box to get room to even get the outlets to fit into the box. It is still fairly tight in there but does not give me room to finish the wiring and or secure the outlets in the box.
I could probably find another way to configure this box but would like to have the switched outlet to run a string light from the box. I could possibly back stab the wiring but hear bad things about this technique, and I am still not sure it would fit without the two outlets touching each other.
Here is the box I am trying to use.
https://www.homedepot.com/p/TAYMAC-...tra-Duty-In-Use-Clear-Cover-MM2420C/302212637
Is there a larger box available or is there a way to make this work?
