I have the wood post that is not vertical as the level in the photos show (The yellow vertical line in the photo maybe just a little bit exaggerated).
Is the bubble in the level within the normal range?
When this wood post was replaced by HOA about 10 years or more ago(they cut the post at the middle about 8 feet out of 16 feet and replaced the bottom 8 feet only joining the 2 post at the balcony floor level. I learned this from Nealtw in this forum), I think they did not put the wood post vertically. Because the wood post is not upright, I think the metal bracket at the bottom is (made?) bent and the wood post bottom sits partly on the lawn soil.
If I cut out the bottom 6" wood thus breaking the metal and wood join, can this vertical problem be corrected automatically? If not, how do I make this post vertical? Do I need to either tighten or loosen the following bolt on the wood post?
Or is it impossible to make the wood post straight vertical because of the un-straight or un-even cut of the wood post at the top thus joining the top post slopingly near the balcony floor or because of the joist hanger metal?
This wood post is the one I asked question on this post , and I am working on this wood post.
Thank you very much.
