I am replacing the carpeting on the stairs with wood treads and I want to do that so the stairs are within code (of course) and also so that they look nice enough when I am done. I first considered hiring a professional to completely tear out the existing stairs (treads, risers, housed stringer on right side, open stringer on left side, etc.) and install new stairs. After getting a few quotes to do that (expensive) and thinking things through a bit more I decided to install 'retro treads" instead. One of the 'problems' I have come across with a retro tread install is that there is a sizable gap (about 3/4") between the starting step riser and the floor tiles. This happened because the floor tiles were installed while the carpet was in place and the tile installer didn't take care to avoid this gap (my bad for not dealing with this at the time the floor tiles were installed but it was not noticable at the time). Anyway, to deal with this problem now, I thought of two possible methods for the retro tread install:
1) Add a 3/4" thick riser board to all steps so that all step treads would remain 11 1/4" deep (from front of riser to leading end of bull nosing).
2) Add a 3/4" thick riser board to only the starting step and use a starting step tread that is 3/4" deeper. In other words, the starting step tread would be 12" deep while the other step treads would remain 11 1/4" deep. The remaining risers (which are mitered to the outside stringer) would remain uncovered and painted to match the housed stringer on the right and the outside stringer on the left.
I presume that method 1) would be the right way to do it but it has its complications (mitering the left edge of the new riser to a new skirtboard attached to the outside of the existing outside stringer, extending the landing bull nose out another 3/4", etc). I prefer to use method 2) but I am not sure if the 12" deep first step tread would be within code. I am hoping there is some flexibility in the code for a starting step but I didn't see anything mentioned in what I have read so far. Does anyone know this one way or the other with certainty? I am located in California if that matters.
Thanks
By the way, I did start a different thread earlier related to this project, asking about the housed stringer, but I thought it best to start a new topic as this question is a bit off topic for that thread. Just thought I would mention it....
http://www.diychatroom.com/f14/shou...ling-new-retro-treads-existing-stairs-171739/
Thanks
