I thought I just had a burnt out light bulb in a can light, but after I replaced it, the new bulb immediately burnt out. I put another bulb in the socket and nothing happens now. Is this fixable without replacing the can? Or should i just replace it? I have access to it in the attic.
Fixed it. It was a loose black wire in the box at the can.
Question:
It looks like the black wire that runs into the can cavity is connected to a green wire purposely by the factory inside a plastic connector in the can. That green wire then goes to the ground on the bulb contacts. The white wire is on the hot tab of the bulb. Why is this? I always thought black was hot and white was neutral. Is it because this series of cans is on a 3 way?
I would get out a voltmeter and start making some voltage measurements.
Assuming the light is on a light switch ckt....no telling what color they used from the switch to your light....I personally would never tie a black and green together...even if the black was at ground potential....that is how people get hurt and equipment damaged....
The white wire should go to the socket shell. The black wire should go to the contact at the inside center of the socket to touch the end contact on the lamp.
This is an older thread, you may not receive a response, and could
be reviving an old thread. Please consider creating a new thread.
DIY Home Improvement Forum
