I'm in Ontario, Canada ...
I'm working with a drain from a laundry tub. Are there any rules in the plumbing code that say I cannot use a union:
a. Between the fixture and its trap?
b. In the trap arm?
Thanks ..
Guy
Long-Time DIYer
A. I'm not a licensed pro plumber.
B. I'm not from Canada.
C. I do not know plumbing code well.
D. I'm just an old DIYer.
E. I know of no reason that someone couldn't use a union in a non-pressurized drain line as long as it didn't leak.
F. Make an anonymous call to your local Building Inspection Department and ask if you want.
G. Go ahead and use the union.
Good luck!
Mike
A "Handy Husband"
Not sure code wise but the issue I see is most unions are smaller ID than the pipe. Why not use a Fernco type connector? you get full diameter of the pipe and they are code compliant in most areas.
Doing it myself
All code issues aside, using a tubular tailpiece/trap underneath the sink gives you multiple union points.
Clear that with inspector and you're golden.
We ARE allowed to use these in our area.
Any joint in a drain line is where it will form a clog. Most piping under a sink has slip-joint connectors with friction type nuts or threaded connector. I have never seen an actual"union"in a drain pipe. Normally would be a Fernco or No-hub coupling.
