Hello,
I am in process of installing an acrylic shower pan. I need to install a rubber caulk seal gasket between shower pan drain and 2" PVC pipe.
The installation manual says:
" Lubricate both caulk seal gasket (1) and drain pipe (2) with either liquid hand soap or dishwashing liquid, and slide the caulk seal gasket over the drain pipe."
Can I ( or, Do I need to) use some pipe dope between rubber gasket and shower drain and PVC pipe for better sealing?
Thanks
Thanks
