@tgm1024 Ah good, then you're just running the raw cables, lots easier to get through without the connectors.
The slot method would help you get cables to a keystone box/lv box/electrical box thing. It could help you feed the cables through the walls bottom plate. I think you'd have to do a ceiling slot to get it through the double top plate. Though you might only have to do the slots /IF/ it gets stuck along the way - cause it's most likely to get stuck at a plate hole.
To explain briefly as I can (I'm long winded sorry), the top/bottom plates are part of the walls 2by structure (under the drywall):
If you've got a platform build like me (I think that's the standard past 80 years) with 2 by wood framing, then the wall's (built like pic above) are holding up a "platform" that consists of a ceiling drywall, floor joists, subfloor sandwich, and the next floors walls sit on top of that. This might help explain a bit better:
That's my second floor office wall where we pulled the subflooring and you can see that wall sits on the subfloor, sitting on the joists, and under the joists is the ceiling drywall from downstairs - also all my cables that run through the floor in there (I ran HDMI, Ethernet, Coax, and IR cables to the game room and kitchen below.)
I've got the wall off the back side of my other distribution point (the one I made the custom coax cables for):
The flat horizontal 2x4 that all the cables run through is the "bottom plate" then you can see here:
the "double top plate" along the ceiling in the game room below. The cables on the left side will go to the basement. And the ones on the right side I cut a slot in the ceiling to retrieve them for other rooms, that slot will be covered by crown.
Anyway, when you run the cables, you've gotta get them through the holes drilled through the top and bottom plates of every wall intersection. The slot would just help you feed them through the holes in the plates, but you'd have to figure out where the slots needed to go...
Another option if things get stuck is a sub floor hole like I did in the second picture. It's a small enough square that a hard flooring wouldn't have trouble bridging. Could patch it with a strip of wood too (just screw "down" through the subfloor into it - don't hit any wires though!) It's the smaller square cut-out in the corner was plenty big to let me to route an Ethernet cable and a coax up through the bottom plate hole I drilled on the right side wall, and it also let me fish all the cables across and down to the game room. The ones I mentioned that go into the basement, we actually drilled up through the double top plate and used a magnet and a chain attachment on the fish stick in order to fish the cables through the top plate hole.
