1 - 14 of 14 Posts
Hi there.
I'm looking to put in a overfill pan to minor leaks. Opposite side of wall is bathtub which has a 1.5" P trap underneth. Can I Tee into that without any issues?
Doing it myself
The only provision I know of that MY local code makes is that a condensate waste discharge line may be tied into the vertical portion of a bathtub overflow pipe.
Premium Member
Hi there.
What is an "overfill pan to minor leaks"?
Reactions: plummen
Master Plumber
That would fall under the category of a water heater drip pan. by code these drains can not be piped in to the sanitary system unless via an indirect drain with a self priming trapped line.(your close but no cigar) what do you think would happen if you ended up with a clog in that bathroom branch or the main.but again depending on your location this may not be true to code. under the IPC thats a no no.
should drain in to the green area (yard) if this is not possible then you do have other options that will keep you flood free and within code.
Roofmaster
Hi there.
Either I am still suffering from a bad cold, or what you said makes no sense at all. What in gods name does "I'm looking to put in a overfill pan to minor leaks" mean???????
Did you read what you asked? Do you mean
"I want to install a stand-tube to monitor leaks?"
Master Plumber
yes i feel your pain with some of these post. :wallbash: what he want to install is a drip pan for the washing machine same as a water heater drip/safety pan only these are for your washing machines. at least i think thats what he wants.
Discussion Starter · #11 · (Edited)
"indirect drain"...so like a wash tub or something? hum...Perhaps I could send it down to the one in my basement...That washtub empties out into a basement floor drain. Don't know if it's self priming but it always seems to have water in it. Do you think it likely is self priming?
How does one keep cold air out from the outside?
Discussion Starter · #14 ·
.thanks just im:whistling2:
i think ill go with this method. im just trying to cstch minor overflow issues and turns out utility sink is not easily reachable.
1 - 14 of 14 Posts
