Hi folks, I've got a lot of electrical archaeology in my place that I'm trying to figure out, even after a decade. Here’s the current stupid and scary situation brought to my attention as I contemplated adding a new subpanel: I think the main panel for my apartment is dangerously out of code. It’s a QO series L5, 6 circuit panel wired directly to the meter by #4 THW, and has no main on board. So it suddenly became obvious there’s technically nothing stopping me from adding another 60A 2 pole breaker, and being able to run way more than the 85A the #4 is rated. The next protection is the 150A building main, not good. I’ve looked at this thing for years without realizing this. Fortunately, with gas heat and range, there's nothing been pulling much serious power.
I’m now thinking the panel was probably swapped out for the original 2 pole main on the service by the buildings previous owners (who were not the swiftest) when they wanted to add some circuits. Another clue is the fact that it’s upside down! Why this was done has puzzled me for years, my best guess is they didn't have enough wire from the meter to reach the main lug if it was right side up. So now you push them DOWN to reset!
Unfortunately a normal size load center with a built in mains can’t possibly fit in the space, it’s only 16” from the top of the meter pan to the joist above. Is there any reason I can’t simply use an 80A 2 pole breaker on the buss as a main as long as I label it clearly? I recall seeing other panels set up like that. Then I’d have room for 2 more 2 pole breakers for the subpanels. But maybe there was more to it on those panels that I didn't catch. Or if someone can suggest a small panel with a mains that will fit, that would work too. I’ve perused the Schneider catalog without success.
Thank for any thoughts.
