thisWhat exactly is an in wall power kit?
No those piece of equipment cannot be run thru walls.this
Amazon.com: Wiremold ZKT101 In Wall Flat Screen TV Wire and Cable Hider Organizer Recessed In Wall Cord Management Kit, White : Everything Else
Buy Wiremold ZKT101 In Wall Flat Screen TV Wire and Cable Hider Organizer Recessed In Wall Cord Management Kit, White: Everything Else - Amazon.com ✓ FREE DELIVERY possible on eligible purchaseswww.amazon.com
400.12 Uses Not Permitted.
Unless specifically permitted in 400.10, flexible cords, flexible cables, cord sets, and power supply cords shall not be used for the following:
- (1)
As a substitute for the fixed wiring of a structure- (2)
Where run through holes in walls, structural ceilings, suspended ceilings, dropped ceilings, or floors- (3)
Where run through doorways, windows, or similar openings- (4)
Where attached to building surfaces
Exception to (4):
Flexible cord and flexible cable shall be permitted to be attached to building surfaces in accordance with 368.56(B) and 590.4.
- (5)
Where concealed by walls, floors, or ceilings or located above suspended or dropped ceilings
Exception to (5):
Flexible cords, flexible cables, and power supply cords shall be permitted if contained within an enclosure for use in other spaces used for environmental air as permitted by 300.22(C)(3).- (6)
Where installed in raceways, except as otherwise permitted in this Code- (7)
Where subject to physical damage
One of the exceptions is in-wall power kits explicitly listed for this purpose. There's a loophole those manufacturers lobbied for.No those piece of equipment cannot be run thru walls.
Sure they can … amazon said so …No those piece of equipment cannot be run thru walls.
well I’m remodeling the room currently, so I was going to cut out an access point above the stud and then drill a hole big enough in the stud so the cord will fit through it. What do you think about that method?That said, I don't know how you can get your specific kit through a hole in a non-ugly, non-annoying way. It's an unbroken piece of romex that's premolded into the plugs on the ends. You would have to splice it. The splice would need to be in a junction box. You would lose some length on the Romex (12" is my guess) to get enough mandatory wire length inside the jbox. I am not sure if code allows the Romex portion to be modified per standard wiring methods (I would assume yes as a guess).
You sure you want this?
There are other versions of this where the Romex is not premolded on both ends, rather either one or both ends are screwed onto terminals. This allows you to get it through a reasonable sized hole without cutting and without extra jboxes.
Amazon stuff is dodgy as heck. You need to check if the item is UL-Listed. My sense is "mayyyyybe...." as it is sold by Amazon Proper (not 3rd parties) and counterfeiting Legrand Wiremold's brand is a lot bolder than the Chinese usually get.
That's a completely different product that works a different way.One of the exceptions is in-wall power kits explicitly listed for this purpose. There's a loophole those manufacturers lobbied for.
Legrand radiant In-Wall Outlet Relocation Kit
How is this product that uses a cord to extend power from one outlet to another not a 400.12(A) violation?forums.mikeholt.com
If you use an approved kit that has you self-terminate the Romex, (or build your own kit with two junction boxes, an outlet, inlet and some Romex), then you will only need to get a bare plugless Romex cable through the hole, and that will fit alongside the existing Romex in the existing hole.well I’m remodeling the room currently, so I was going to cut out an access point above the stud and then drill a hole big enough in the stud so the cord will fit through it. What do you think about that method?
I think you're going to need a pretty big hole to get the cord plug to fit through, and it's going to require a good drilling equipment/skills and may still end up looking pretty massacred.well I’m remodeling the room currently, so I was going to cut out an access point above the stud and then drill a hole big enough in the stud so the cord will fit through it. What do you think about that method?
interior ceiling or wall pic ?Would it be ok if I drilled a hole next to the electrical wire hole to run my in-wall power kit through it?
400.10 A (11)
Between an existing receptacle outlet and an inlet, where the inlet provides power to an additional single receptacle outlet. The wiring interconnecting the inlet to the single receptacle outlet shall be a Chapter 3 wiring method. The inlet, receptacle outlet, and Chapter 3 wiring method, including the flexible cord and fittings, shall be a listed assembly specific for this application.
Another reason I think the exception is needed is that the flex cord might otherwise be considered part of the permanent wiring in the building. Which is generally otherwise a no-no even if it’s outside the wall (the permitted stuff notwithstanding, EG there’s this section we are discussing, along with a lot of exceptions for powering utilization equipment).Surprised me!
wall picinterior ceiling or wall pic ?
