Is this acceptable, or is it one wire per space (which seems really loose!)?
What does the bag state?Is this acceptable, or is it one wire per space (which seems really loose!)?
Is that a 42 cu in box? Should be stamped inside the back. You're going to have 3 switches? 2 hooked up to 14ga and 1 hooked to 12ga?Do I need to go bigger for more capacity?
SD515 and I agree that the circuit should not be extended due to being 8ngrounded.I am also still in the dark as to this situation. I didn't understand if this would work somehow or not, so I posted a photo of the box. More comments on this would also be most appreciated.
http://www.diychatroom.com/f18/ok-1-extra-wire-now-what-108848/
