Actually I'm putting in a p trap under the bathtub, no compression fitting on this one. Can't shorten the vertical (tailpiece) pipe. I'm wanting to raise up the 90 that connections to the UIf you mean shorten the sinks tailpiece- yes
You can but it is not allowed by code. There is a maximum trap depth- I believe its 4" The reason for this is that a trap must be "self cleaning" Making it deeper allows solids to settle rather then flushing out while draining- or so I'm told...Actually I'm putting in a p trap under the bathtub, no compression fitting on this one. Can't shorten the vertical (tailpiece) pipe. I'm wanting to raise up the 90 that connections to the U
Yeh, you're losing it. He wants to do the opposite. In fact, as I understand it, he wants to make the adjustment at the trap by making it deeperAm I losing it? From that picture it looks like the tailpiece has to be extended so the back of the trap lines up with the T? I cant see anything wrong with that.
