1 - 15 of 15 Posts
Hello, it's the idiot electrician again.
Can I wrap electrical tape around this bare copper?
I can't cut it: there's not enough wire left, and I can't pull it out: it was bent when I pushed it in; in fact, the exposed wire is just insulation I pulled back from trying to pull the wire back out.
If I have to cut it, can I just a wire with electrical tape, or is that just a recipe for disaster?
Thank you for your time.
· Electrical Contractor
There should be a small slot adjacent to the hole where the wire is inserted. Press a small screwdriver into that slot, and that should release the stronghold on your wire.
Once you get the wire removed, bend a hook in it, and use the terminal screws instead.
· Licensed Electrical Cont.
But use the screw terminals on a new receptacle. That is an old junk receptacle that is likely near the end of it's usable life anyway.
And you can cut it. There is plenty of wire to make up new. Just cut it right at the back of the device. You'll only lose about 1/2".
Reactions: W_Mitty
Discussion Starter · #9 ·
Black wire is looping the screw in the wrong direction looks like.:yes:
Remember? That was mentioned in your other identical thread. This is why one thread per topic would be best.:)
Yeah, I absentmindedly thought the same direction as in "both should start on the top and curl down." Notice I did do the white correctly - this time.
Sorry, I started a new thread since I thought the topic was separate: the first topic concerned excess copper from a screw, while the second concerned excess copper from the back of the plug; then I continued in the second thread as, yeah, I thought three threads might be a bit much.
Thank you everyone for the help; I don't want to die in a fire.
· Super Moderator
The insulation on the white looks like it is under the screw head. Only bare copper under the screw head.
Also if that is #12 it cannot be used in the backstabs. Only #14 in the backstabs.
1 - 15 of 15 Posts
