I am turning a storage building out in the middle of nowhere into a rustic mountain cabin. For this project, I am all about functional and cheap.
I will need to install several new windows into spots where no windows were before, so I will have to cut and frame new openings. The existing siding is T1-11 nailed to the studs (no OSB or anything underneath). I bought several used double-pane aluminum sliders with nailing flanges for super cheap (they had been removed from an apartment complex).
The guy I bought them from (a contractor) said I can just cut and frame my opening and nail or screw the flanges straight to the siding. He didn't mention how to seal that. I don't see how that can be done in a way that will keep water out. Seems like at the top of the opening I need to tuck a drip cap under the siding and over the flange and edge of the window to divert water out, which means I will need to cut the siding back and fasten the flange to the framing. Also, I plan to trim out the window with 1x4s, if that matters.
Am I missing something here? Is there a way to fasten the flange directly to the siding and flash it to keep water out? Or do I need to cut the siding back a few inches, flash and then cover the gap with trim?
Also, how should I handle the sides and bottom? Can I just cover the nail flange with adhesive membrane, or maybe use a piece of flashing on the bottom to divert water to the outside of the siding and then hide it with 1x4 trim?
Thanks for the help. Most of the installation instructions I've found online are for buildings with sheathing and then siding on top that can be taken off.
