Whenever it rains, one corner of my parents' basement is always very wet, and it appears to be coming up through the floor.
I assume a sump in that corner of the basement is the way to go?
How hard is it to do myself? What is the best/easiest way to cut through the concrete floor?
How close to the actual water problem does the pump need to be? If it's 5-10 feet away, would that still work? Or does it need to be right where the problem is?
How long can the pvc be from the pump? Ideally, I'd want to push the water out the opposite corner of the house, which would be about 40' away, so that the water would flow downhill when it exited the house.
Thanks.
Thanks.
