So would a single pole switch. What is your point?the three way defeats the remote.you need constant power to fan/lite.why do you guy's always want to screw with things?
the point is with a three-way,every time you want to use fan/lite,you need to flip one of the three way switches to get power to fan/lite.and yes one single pole sw is eaiser.if you use the three-way idea,turn switches so fan/lite comes on,then buy those plastic screw on devices that prevent switches from operating.the if you want to work on fan/lite,remove the stop on one of the 3-way switches,turn power off,turn plastic locking device screwed to other plate screw so no one can turn power on.when done return locking device to stop power from being turned off so remote works.So would a single pole switch. What is your point?
if he uses only one sw,a single pole is fine.Actually not brcc.
Makes no sense at all. If the circuit is on the remotes will work.if he uses only one sw,a single pole is fine.
Why not? They work fine in my house.Actually not brcc.
if someone truns off one of the three-way switches,no power to lite/fan.there for no workie..Makes no sense at all. If the circuit is on the remotes will work.
That should be understood. It's the same with a single switch. If you turn a switched receptacle off it wont work either.if someone truns off one of the three-way switches,no power to lite/fan.there for no workie..
