I just purchased a new (downflow) system for my "split-level" house including the a-coil, furnace and condenser unit. The old system was configured with the a-coil under the house, which I am not wanting to do anymore because of servicing issues.
Unfortunately, the new coil and furnace are too tall to go in the existing space without modifications. Also, as you can see from my drawing, I still need the plenum box at the bottom, so I can't really get rid of too much vertical distance on the supply end.
One thing I though about doing was to "cut" into the side of the furnace for the return air and then just plug the top. That would save me all that wasted space above the furnace.
I would love to have an opinion from the experts on this board, before I start cutting into my new furnace
Also, just FYI, the blower motor is on the opposite side of where I would be cutting, so at least the air would be going directly into the side of the blower.
I can provide better explanation on any of this, if needed.
Please see my attached drawing, or if it is not attached, I will try to figure out another way to post it.
thanks!
thanks!
