I have a food pantry off of my kitchen that is very warm in the summer and cold in the winter. The outside wall of the pantry, on one side, is the garage and the other side backs to the interior of the home.
There is a wall register about 10 feet away, on the outside of the pantry. The register is exactly what I need for my pantry just in the the wrong spot.
My question is, I am not sure how ducts "typically" run through walls. The opening in the duct in the wall pictured has the opening on the bottom. Is it possible to cut a hole through the wall into the duct and simply add a wall register to all air to access my pantry if the duct does run parallel? Since the hole in the existing vent has the hole on the bottom, does that mean that the duct work would not run parallel in the wall to the pantry area? As you are looking at the picture, the desired vent would go to the right into my pantry which is on the other side of the brown stained wall.
I hope that I am explaining my thoughts correctly. Please let me know if I can clarify better.
