I want to lay 12x12 porcelain tile in my utility room that has a concrete slab floor. The concrete is 3/4 inch lower than the top of the backerboard under the matching tile in the adjoining kitchen. The kitchen tile is on 3/4 inch plywood, thin set, hardie board, thin set and then tile. I need to go up 3/4 inch before I lay thin set and tile. If I lay Ditra on the concrete, can I use a thicker bed of thin set to set the tile to match the height in the kitchen? I imagine the thin set would have to be around 5/8 - 3/4 inch thick. Is this all wrong? Can I use two layers of Ditra with thin set between them? Should I use SLC or pour mud bed? Should I abandon the DIY approach and call in a professional? All suggestions are greatly appreciated. Have a good day.
You can see my other post titled "Continuing tile from kitchen into utility room" for more info if needed or ask a question. Thanks
