I am looking into getting some bamboo flooring. They only come in prefinished with aluminum oxide.
I am curious, later down the road, if I need to refinish the flooring, can it be done? I've been told its the same process as refinishing standard hardwood floor. Is that true? Can you use polyurethane on bamboo? How about staining?
Is it possible to refinish with the same aluminum oxide?
I am leaning towards strand woven carbonized bamboo 5/8" if I do bamboo at all. Other bamboo construction is too soft (so I hear). Otherwise, I'd rather go with standard hardwood.
