1 - 12 of 12 Posts
Looking at purchasing a unit that heats water with the usual immersed coil-thingy, but it is designed to be used in the Middle East on 240 V service. Seller says it has been used in the U.S. with an adapter.
Does such and adapter really exist? I can't imagine it would permit full heating power. Adapters surely work the other way around...permitting 115V appliances to be usde on stepped down on 240V service?
Thanks.
i would check with the manufacturer and see if 115 volt heating element is available for the unit. pictures would help. why not run it on 240?
Or run a new dedacated line and breaker to run just that.
There are adapters, though it will likely take twice as long to heat the water.
4X. P=V**2/R
I needed space in my panel box, so I ran a 240 baseboard heater on 120v. It got warm, which was all I needed.
I am sure there are step up transformers available, but they would cost more than a 120v kettle and probably require more than a 20a outlet.
Retired Moderator
Why buy one that doesn't work without jury rigging it?
Look for one that is already wired for 110---
Am I missing something here?
I do not think your missing anything, it just sounds like someone who does not how these work and how bad an idea it is.
If the O/P could tell us what there really trying to do with this thing I'm sure someone could come up with a better safe way to do it.
Haverhill Trade 1965
I had a 240v compressor that I had to find power for on jobs. I had a short extension cord adapter that went to dryer or electric stove outlet.
Just read that again. You have to check one other thing. Many countries use a different cycle too. I know Germany used to use 50 cycle 220 volt.
A "Handy Husband"
A heating device designed to work on 220-240 will only use 25% power when connected to 120 volts. It will take forever to heat.
1 - 12 of 12 Posts
