I have installed a 5700 cfm wholehouse fan and would like someone to tell me how much exhaust space is needed for it to operate most efficiently. I need to know how to test for enough exhaust and how to calculate the amount needed for this size of fan. Thanks.
· Banned
An air change in ~8 minutes?
One rule of thumb is that the intake area = 4x the fan blade swept area.
· Banned
It's probably the same 4x rule; incoming air = outgoing air and since the outgoing air is under pressure it would need even less than 4x.
For more precision you need the fan curve,
http://www.cartage.org.lb/en/themes...mics/Lowspeed/Aboutfans/FanCurve/FanCurve.htm
showing pressure vs. CFM, then you need to be operating the fan in an area of that curve recommended by the manuf.
Some fan curves are "S" shaped, which makes for unstable regions in the curve.
· In Loving Memory
Roughly 1444 sq in free area.
2-16 X 32 louvered grilles(if gable vents) should give you the area you need.
