In the US, a white colored conductor is allowed to be used for a live conductor when it's the 12/2 feed cable to a switch leg. I never see it re-identified... electricians are expected to know that the white wire on a 12/2 cable for a switch is the hot wire.
Personally, I always tag it with some method to set it apart, often just a hash/gash made with my wire stripper (covered by the wire nut). It's mostly out of habit and for consideration to the next man opening the boxes.
It helped when someone different than the rough-in puller, was making up the boxes. Any man who wired a switch across the line was made "sport of the day" and expected to treat the rest of the crew to free refreshments.
SD2
When I worked telco, 99% of my wire work was done with a pair of Klein 6-inch side cutters.Don't laugh when you see the high tech strippers that took me all the way to the rocking chair. Once you get the feel of them, you'll not want anything bigger... size matters, especially when it's going in a tool pouch.
I can't believe Klein got the wrong size cutters in that stripper... I'd take it back and trade it for a Miller 100 (no spring model). :smile:
I agree. The Klein Katapult I have is advertised as "Cuts and strips 8-20 AWG solid and 10-22 AWG stranded wire. When I have some time, I may have get some different kinds of wire and experiment with it.Some strippers are marked for "solid" and "stranded". You need to look closely as often the gage is indicated by a single number (#12 for example) and the correct notch is indicated by a fine line or arrow. I've always found Klein to be pretty good quality for the price. It's hard to imagine they are marked incorrectly or out of spec.
