1 - 7 of 7 Posts
I have finished wiring and mounting 12 recessed can lights. I forgot to use cable clamps on the wires coming into and leaving the junction boxes. I am wondering if cable clamps are really necessary before I finish the ceiling and it is much more difficult to get to the fixtures.
How much of a safety risk do I have without the clamps?
you might want to check before investing a bunch of time in installation, our area allows the split plastic type that you can install with out removing all the wires and re-attaching.
Rip
Just the risk of the sharp edge from the box, over time, cutting into the cable causing a fire that burns the house down, and hopefully does not kill your family.
Plastic bushings are ok, if they are the kind that is actully a cable clamp built into the bushing.
If you do not plan to do the job right, just light the match now.
...Plastic bushings are ok, if they are the kind that is actully a cable clamp built into the bushing....
Glad you added that...it's what I meant...but didn't get it in....:whistling2:
Rip
1 - 7 of 7 Posts
