1 - 20 of 26 Posts
Hello........
I am brand new to this forum but I am desperate for some ideas/help deciding how to solve my paint dilemma. I am doing a low budget kitchen redo, meaning I am painting my cabinets instead of replacing!! I have decided to paint the upper cabinets antique white and add wooden appliques to "dress them up. My base cabinets are going to be a deep brown. We are tiling my backsplash and countertops. My dilemma is that I have a floore to ceiling cabinet with my wall oven that has one side butting against the countertops with upper and base cabinets .........not the problem, but what do I do with the other side. I have no idea how to paint this to divide my paint colors correctly. Right now this is stained wood.I need advise on how to divide the upper from the bottom since my cabinet houses the oven and has stained wood all around it. Help.......please......
I don't think I was clear enough with my question...........since I plan to paint the upper cabinets antique white and the lower ones dark brown, I dont know how to divide this cabinet. You can see cabinet on the sides of the oven so there is not a clear line where the upper meets the lower. The wall side is solid so there is no dividing line there either. I considered painting that entire cabinet brown and then where the uppers beside it meet change to the light color. but I dont know know how that would look. I also thought about adding a think molding on the wall portion but there is not enough room to add it to the front anywhere close to the counter top.
Discussion Starter · #6 ·
No, it is not vital that I seperate that cabinet into two colors..........just unsure what to do. My husband votes for painting it the brown color. the upper cabinets over the oven would be the only dark cabinets. all other uppers will be the antique white.
I actually think the option above of turning the entire wall into some sort of message center for the family was brilliant. You could chose to cover the entire thing in cork for a pin board, it could be framed out and painted with dry erase or blackboard paint - the options for that are endless. If this is a convenient area in your home for centralized information, I would absolutely agree with that suggestion.
Discussion Starter · #11 · (Edited)
I appreciate all the ideas very much........I am not sure about the message board idea, although I do really like the idea, and I am sure it would initially look great. However as you can see in the photos, the side of the cabinet is very very close to the doorway and it is the door that we use most because it comes in from the garage. Thus everything that comes in enters through that door and I am thinking that our rubbing against it may create issues. And being a stay at home mom, I really have little need to leave messages. So, as yet that is still undecided. As for the face of the cabinet, I am leaning towards painting the whole thing dark brown to match the other lower cabinets since I chose that color to help hide little fingerprints and paw prints of the grandchildren and granddogs. I am hoping that since the entire cabinet is counter deep, painting the upper cabinets dark will appear intentional, as if we wanted to create a focal point. (one can only hope....lol) Again, thanks for the great ideas. I will try to post some after photos when we are done......but please be patient, we are doing most of the work ourselves and it may take a couple of weeks.
my two cents
Hi,
Maybe you can paint it the top cabinet color, but glue square trim pieces that are painted the bottom color. like this:
http://www.thisoldhouse.com/toh/video/0,,20247261,00.html
Or, something that might look cool is to put glass tiles on it. A third element, but it can tie in the top and the bottom if you chose the color correctly. It's not too much tile, and it would be more expensive than paint, but might look quite lovely.
Discussion Starter · #13 ·
Well.......we took a deep breath and just decided to paint that tall cabinet to match the bottom ones. I think it looks great. I actually like the contrast where the other creamy upper cabinets meet the dark brown. We also got the appliques on the doors and again, I am loving them. We havent put the doors back on yet, (hopefully this weekend we can get them up) and I will post pictures when we do. And again when the countertop and backsplash are in. Thanks for all the interest and ideas.
Discussion Starter · #16 ·
Thanks.........It took us a little over a week. Ours were in such bad shape that it took quite a bit of sanding. We sanded and primed and we sprayed the doors. And then let everything "cure" for 4 days, to make sure we didn't mess up the finish. But overall I am happy with the way they look.
kitchen cabinet help
Hi,
I understand what you're looking to do with that long cabinet. Two options- Measure halfway up the wall. Chair rail, then cork board, or black board the top section and frame it out with trim/molding. I think dry erase looks sloppy and cheap.
Option two- Paint all the cabinets antique white. Your cabinets are old and dated. They need bright and light. The only time I think the two tone looks good in when the kitchen is modern, expensive, with clean lines.
Only my opinion but if you go with the off white you can add color splashes with tile, new counter, and shiny new bronzed hardware.
Also if this is your first time painting cabinets make sure you use an eggshell paint AFTER you've fully prepped. Prep is THE most important step. Use TSP and thoroughly clean every inch of the cabinets before priming. Once your second coat of paint is dry use polycrylic semi-gloss(blue can) in CLEAR or else your paint will "yellow" apply several coats with a foam pad on a wood stick.
Taking this route will avoid brush marks unless you are an expert cabinet painter. Hope this helps:thumbup:
actually all your cabinets don't have to be painted the same color. Their old cabinets were old fashioned, her current ones look more traditional now with the added decorative moulding (nice touch by the way). They have brought their outdated kitchen to the present without having to spend a fortune on new cabinets.
I happen to love contemporary design, but I still like what they have done. As soon as a slammin' backsplash goes up it will be fabulous, and once that new countertop goes in, it will be stunning because they did it themselves!
Discussion Starter · #19 ·
Thank you klmeenan! My kitchen was so ugly and worn out when we started, that almost anything would have been an improvement. And although I am personally pleased with how they look right now, I am still second guessing myself on my choices (which drives my husband nuts). We will be starting the countertops and backsplash this weekend, and hopefull I will have more pictures to share very soon.
I'm curious as to what you plan to do for a countertop and for the backsplash.
I will have to post my moms horrible kitchen. It used to be worse than it is now. It had a faux brick for the backsplash and some awful thick black stuff for "mortar". It was horrible to get off. We have no money so I took it off and got everything as flat as I could then layered on some compound. Then I painted a really horrible fake (so bad I can't call it faux) tile. She wanted to see how it would look if she did tile. Stayed that way for 14 years. She is too busy raising one of her grandkids and now taking care of her 90 year old day. She is retired so she still has no money and has champagne tastes on a soda budget.
I saved my yardsale money and I have started cleaning her cabinets trying to make sure I get every bit of grease and dirt off them. I can't wait til I can start painting them.
1 - 20 of 26 Posts
