1 - 7 of 7 Posts
Learning by Doing
My dear sweet husband bought a portable lift for our detached garage (it's 75 feet from our house and has power) a month ago. He has spent the last three weekends trying to put it in. It has been a hassle and a half. Tonight I volunteered to babysit my neighbor's kids so he could help my husband finish setting it up and so I could avoid having to divorce my husband over the stupid lift. :laughing:
They came in at 9:00pm tonight and my husband says (like it is NO BIG DEAL): "I need a 30 AMP dedicated circuit to operate the lift." :censored::censored:
This would have been useful information to have a month ago.
Leah, you mentioned that the garage has power. Does it have its' own sub-panel, or just one circuit to a light and outlet? If it has a panel, it shouldn't be too tough for an electrician to provide power to the lift.
If there is just one 120v 15 or 20amp circuit, you'll have to look into how it is powered.
If there is direct-burial cable, a trench will need to be dug out to the garage for the new power.
If there is a pipe run the whole way, you may get lucky and be able to add the necessary 30 amp wires too it (depends on size of pipe).
Either way you need to call a licensed electrician to get 'er done.
Look on the bright side, once the lift is in there, he'll spend even more time in there....priceless.
Electrical Contractor
How much juice you got out there, Leah? Inquiring minds want to know ...
If you do not already have a 10 gauge 3 conductor (120.240 volt) circuit you will need to restring the entire feed from the main house. Only one circuit (either 120 volt only or 120.240 volt) is permitted between any two buildings. You may as well put in 6 gauge wires (red, white, black, 8 gauge green) for a 60 amp 120/240 volt circuit and thus provide for the future.
Include a subpanel if one is not already there.
Learning by Doing
Discussion Starter #5
Thankfully, the garage was wired with substantial capacity. We've got 90 AMPS running to a sub-panel in the garage. But my husband had NO CLUE as to this, he just assumed it would be fine. :wallbash:
I'm the electrician, so I guess I know what I'll be doing next week. In my county homeowners can do their own work, so long as they get it inspected.
1 - 7 of 7 Posts
