What is this HVAC make/model as the sticker has lost color and is now white. The house was built around the year 2002 so the HVAC should be from around that time.
The Problem: No cool air upstairs (this is the upstairs unit, the other unit for downstairs is cooling and is newer).
Checked this HVAC unit outside (the gray one pictured) and there is a buzzing sound and the fan area above the unit is hot to touch. If the piece is taken out of the shut off switch and left out for several minutes, then upon putting it back in there is a sound like the unit wants to start but it does not.
The picture with numbers and text is of fan's sticker, maybe it helps with identifying the unit. Also a picture of the compressor and its wiring for the same reason.
Thank you for your input and help.
