I am putting a new circuit in and I am ready to connect it into the breaker box. I am not all that knowledgable about electrical work and so maybe I just don't understand what I am seeing in my breaker box.
I am adding a 120 volt circuit, 20 amps. There are three of them in the box already. The hot wire attaches to the circuit breaker, no surprise there, and the neutral wire attaches to a bus bar. There are less ground wires than there are circuits, making it difficut to know which circuit has a ground wire. The thing that perplexes me is that they are attached to the same bus bar as the neutral wires.
There is a heavy (about 1/4") copper rod attaching the only other bus bar in the box to the one in question. So, two bus bars connected by the copper rod one has all of the neutral and ground wires in it, the other is not being used at all. All of the neutral wires are below the copper rod, the neutral wires are above it. is this coincidence or is the rod some kind of divider?
I can't see how the rod would divide the bus bar. Can someone out there shed some light on this?
