Hoping this is the correct area for this question....
I would like to bury the coax cable for my cable tv in the ground, but have a few questions first.
I am pretty certain that the line is rated for direct bury, I'll of course double check, but I'm actually thinking of pulling it through some 3/4" gray PVC electrical conduit just for added protection. I know a bit overkill, but I have dogs that tend to sometimes dig and the most direct path is very near a very large maple tree and a medium sized mulberry tree. I figure if in the PVC, if the tree encroaches, it's better protected in PVC..... I also don't really plan to bury it, but lay it on top of the ground right between fence posts and fence boards and cover with mulch for most of the distance. Any issues with this?
Next, if I come out of the PVC, how do I terminate the end near the pole? I asked the cable company about this a few years back and I'm sure they said they would just direct bury it, so do I just stop the PVC and plug the end after the cable goes through or use a weather head?
What about splices??? Is it a bad idea to have a splice? If not and if it's inside the conduit, do i need a gel splice or will just any splice do?
I'm actually hoping the cable company will come out and pull a new line for me, but if they won't, well.... Even though, I really want it burried for aesthetic reasons, I actually think I have a geat case to get the cable company to do it for free if I can get the conduit ready to go. When they installed the line originally, they ran it right between a fork in the maple tree and I had to retighten the cable the other day, because the tree was growing up to it and rubbing, when I checked the cable a small section of the insulation had rubbed off. So I want to be prepared when I call them to have them come out and check the line.
Any suggestions on best practices for this is greatly appreciated!
