A few more details....when removing the circulating pump water into the boiler onto the gas valve and components. We removed the gas valve, cleaned with compressed air and reinstalled.
If the ignition module got wet that could be a problem. With the thermostat calling for heat and the pilot on, check the orange and white wires for voltage at the gas valve.
Hoping we can get this fixed. 2 days with no heat in Craig Colorado. We do thankfully have a woodstove that helps but it gets -20 at night. Have called repairman but they can't get out here today .:hushed:
DO NOT hotwire or jump the gas valve or you may have NO safety controls in case the flame fails if the igniton control is damaged. Then you can have raw gas spilling into your hoouse and a explosion.
Not saying you will but people sometimes panic and do unsafe things.
Yes it stops sparking. We did go ahead and order the ignition controller. We are in a rural area and are having problems getting a technician out here. They called and said they would try to work us in tomorrow. I'm not sure we can get to the sensor...its buried in the boiler.
This is an older thread, you may not receive a response, and could
be reviving an old thread. Please consider creating a new thread.
DIY Home Improvement Forum
