I am having problems with interior paint starting to come away from the wall.
The interior wall was painted a few years back and recently I noticed some slight bubbling happening and not thinking too much about it...only that I would need to be doing some painting in the future.
The area has gotten bigger and basically travelled horizontally along the wall. You can take your hand and press against the section of the wall and the paint moves back and forth.
Now I know that the paint is coming away from the plaster wall but WHY would be my question?
This wall is not exterior but does face the west.
The area was painted some years ago without any signs of problems. No other wall in the same room is showing this problem.
Could humidity cause this? I live in Michigan and do run my air when needed.
The wall in question has the cold air return vent and the problem is in that area but not directly next to the cold air return vent.
Thank you for any advice, opinions, and or suggestions relating to my question in advance.
