I'm deciding what to do with my window returns. I have 7 windows that are all about 3' x 6'. The returns are about 4 1/2" deep.
I've done some research and some options that could work are:
1. Drywall returns with metal corner beads. J-trim on the drywall edge that touches the window. I've got plenty of scrap drywall sitting around. A variation of this is to use Denshield (waterproof sheetrock) for the sill.
From what I've read this is a builders grade window return solution. Not a very moisture tolerant surface. Also not great to clean frequently -again moisture being the issue. I could also do densheild all around the window returns. I've got enough scrap.
2. Wood returns with an extended sill. Would require some ripping (I've got a table saw). I could install some type of narrow trim to cover the sheetrock / wood corner to create a modern look. I don't have room for standard trim (one of my windows is right next to the adjacent window). I could paint / stain the wood to complement my bronze windows, adding the appearance of depth to the window.
The window return depth is around 4 1/2". But it's plus or minus a little bit on each window. I could buy or make a taper jig(s) to accommodate the non squareness of the window returns. It's caused by the non levelness of walls not the window positioning.
One window return depth is way off. Again it's caused by the walls. (See diagram). Is this going to cause some issue building wood extension jambs?
Any thoughts on sheetrock (or denshield) vs wood extension jamb returns?
Thanks
Thanks
