1 - 2 of 2 Posts
We have a 10' x 10' metal gazebo that shifts a lot because of wind storms. I had an idea to build L shaped planter boxes for each corner that would sit on the outside of the metal leg frames. The planters would only be wide/deep enough to hold a bulb of elephant ears and some annuals/perennials (maybe a max of 12" tall and 12" wide).
I got to thinking about how the gazebo moves, and was wondering if it would be feasible/sensible to screw the metal frame corners into the planter boxes. Or should I make the planter boxes square, and anchor the legs of the gazebo inside of it somehow? If I go this route, would I need to spray the legs with some sort of sealer so it doesn't rust from dirt/water?
Our gazebo is like the one I've posted here, and I was thinking of the planter boxes going on the outside of the legs.
Difficult call.
If the boxes are outside the curtains hang in them, but if they are inside they take up valuable space.
Any kind of movement against a ground anchor will scrape off paint and start rust if they're not tight.
Try coating the attaching brackets with black plasti-dip first.
1 - 2 of 2 Posts
