Hey gang. I have questions on building a drop in tub deck for tiling. I am fairly handy. My DIY score is 8.5.
I have never built the framing for a drop in tub. I have the worlds heaviest drop in tub. We are reusing a 66" by 32" cast iron drop in. The bottom has four legs that will sit on the floor.
Q1: On top of the 2X framing I should have plywood (I have 23/32 leftovers), Durock (1/2), and tile on top of that, correct?
Q2: My main question that I can't find online is that when the tub deck is tiled should the top of the tile be EXACTLY the height of the tub? Should I allow for a 1/16 or 1/8 gap to caulk when done? Obviously a tub this heavy is not going to rest on the tile. If I should for exactly and am a bit to high, I assume I could shim the tub legs, correct?
Thanks in advance.
B
Thanks in advance.
B
