1 - 13 of 13 Posts
Building code compliance: remove laundry shut off from bathroom wall. What does that mean? Currently the Laundry room and bathroom share the one of the same walls. The laundry shutoff box is installed on the correct side (the laundry room). So I don't understand this code?
Think your confused, we have no idea what your location is, no idea on what it is your even trying to do, no pictures.
Retired Moderator
Tell us what's going on---you will have to ask the code people---
Could it be that you did not mention the work in the permit?
Or are missing the floor drain ,if your area requires one?
Retired Moderator
The homeowner does not know why----nor do we---only the code enforcer has a clue---so he is the one that must answer the question----
Are there any inline, shut-offs for the supply lines in the wall that we can't see - from your pics?
Around here - seen the same set-up - no compliance problem.
As stated above -
Take your pictures into the Building Dept. and ask the person who wrote
this up - what's wrong?
rossfingal
1 - 13 of 13 Posts
