Help
My son is getting married in a couple of weeks and to save money, we are having the wedding reception in our back yard.
We have an in ground, fiberglass spa that is approximately 8' x 10'. There is a concrete coping that sits on top of spa, just like an in ground pool.
Here is a pic:
I need to construct a temporary deck over the spa, so this area can be used for tables:
Here is what I am thinking
1) I would place a four foot long 2x12 on the bottom of the spa as "backup" support. Attached to it would be a 2x6 forming an upside down T:
2) I would then build my framework that would sit down inside the spa, flush with the top of the coping. The joist s would be 2x6's on 18" centers with a 2x4 rim:
3) I would then add blocking and install a couple of vertical supports to tie the two pieces together:
4) The whole thing would be covered with tongue and groove particle board flooring that would be screwed down with 3" "gold screws" every 6 inches. The flooring would extend a couple of feet over the concrete deck. The only thing you would see would be the 3/4" flooring on top of the concrete:
My thoughts are the 2x6's should be able to take the load - but I would also have the "backup" support system at the bottom of the spa in case of problems. Weather shouldn't be an issue, and this would only be in place for a couple of days.
Thoughts?
Here is a pic:
Thoughts?
