1 - 18 of 18 Posts
I am thinking about building a storage shed in my back yard ( it will share a wall with the back of my garage )
I will make it 10 ft wide x 15 ft long to be big enough for all landscaping equipment and tools etc
The question is how many cinderblocks should I put in the ground ? would 2 ontop of each other be ok one being in the ground and one above grade ?
something that would look like that
Another question is what should I use for the floor ? should I lay down plywood ? it will have a riding mower maybe my 8 foot plow etc I can leave it dirt but not sure if I should do that :huh:
the garage is not attatched to the house and it have what looks like 3 or more blocks I can see 2 blocks at low grade and non at high grade
the shed would go in the back of the garage in my back yard maybe I should post a picture of the actual location ?
Banned
If it was attached to the house you match the house foundation depth
Since its not just match the depth of the garage "foundation"
That way the 2 structures should move the same in cold weather
So I should dig till I reach the lowest block and start there I would also bond the new wall to the old foundation ? blocks cemented together right ?
And also do I lay down a layer of cement below the first block in the ground or just ontop ?
I asked about building a storage shed in the back yard they said it must be 10 feet away from property line thats all
But I will check back with them to make sure its ok I guess
Banned
That's actually the main reason I asked
I saw the property line (fence) & it looked somewhat close
Here we have 15' set back
I would dig down & determine how deep the garage foundation/slab/block goes down & match that
For my shed (free standing) addition I poured a 12" deep "foundation"
My main reason was to keep mice out
2nd was to contain fill which will allow me to put blocks in as a floor
At 150 sf, that may be over the "magic" 120 sf that many areas have to avoid codes. This usually applies to unattached structures. This is in addition to the setback zoning requirements. - My son built a 120 sf unattached shed on grade with 10' high walls to avoid the local sf requirements. It was a great storage building because you got multiple levels of storage (dead and current) that fit into the seasonal situation.
It it is attached to an existing structure, that increases the concern for frost and differential movement from frost and temperatures.
If you go to sell in the future, you may have to remove the illegal structure if it is attached and is over the "magic" local sf limit, no matter how long it was there.
Dick
Discussion Starter · #10 ·
Thanks for the reply I will walk in the township and ask whats the magic number around here :whistling2:
If it comes down to taking the structure down when its time to sell that can be done too I need to gain back all my garage space I have an automotive project coming up soon and all the lawn equipment need to get out :yes:
Discussion Starter · #12 ·
I went into the township office today ( saw a couple of things that does not meet code :laughing: ) asked about the magic number for a permit and its 100 st ft :mad: now thats inside space right ?
They need a land survey with a mark on it as to where the shed will go :thumbup: and I am good to go
Concrete & Masonry
That 100 sq. feet max probably applies to a detatched shed. I would imagine you could go bigger if attatching to the existing garage, assuming you do similar (to the garage) frost footings.
Even if you are pretty sure there is no buried utilities, call you version of MissDig before starting to move dirt (or incurring much other expense). They'll mark locate all the buried electrical and gas lines etc.
I recently built (from scratch) a ca 100 sf shed (8x12) with four cinder block feet at the corners. The shed sits about 8 inches, or the thickness of the blocks, above ground. In hindsight I should have had six feet in all, three along each 12 foot side. Some sagging has occurred halfway across the front even though I used double 2x6 rim joists. The blocks sit on slightly larger pads of tamped gravel flush with the ground and about 12 inches deep.
My city requires a permit for a shed of any size, and there are setback requirements.
More details: http://www.Cockam.com/shed.htm
For a 10x15 shed, I would want at least 3 block feet from side to side and three block feet from front to rear. Putting the blocks along the perimeter under the rim joists is no problem but there needs to be support such as a center beam for the middles of all the joists, to keep any of the joists from sagging because it did not have a concrete block foot directly under it.
Or use 2x8 joists, and 8 blocks, 4 along the front and 4 along the back.
1 - 18 of 18 Posts
