So, I'm building a new deck at my house and wanted to share my plan and get suggestions, ideas, and comments. I posted over at gardenweb, but it seems like the whole forum there (while FULL of great posts) isn't getting hardly any new posts or replies AT ALL.
Per a couple suggestions, I'm breaking this into a few threads regarding the deck and the granite ideas so please see the other threads about the granite.
Additionally, I've gained access to scrap granite from a countertop installer and I have a few ideas. I'll share those ideas in a separate thread so please look for it and give all suggestions and comments you can.
Thanks
DECK:
Ok, so the deck. Due to my door elevation, and the grade behind the house, here is the plan:
At a sliding glass door off my sunroom, I've already built a 15'x10'ft section that runs the length of the sunroom that you see in the picture. The two corners away from the house, near those trees are "chamfered off" 3ft back from the corner both ways. That gives the angled sides to be 4'3" long.
From that, I'm stepping up (and continuing down beside the house, towards the fireplace 18ft, and out into the yard 18ft. It'll actually be 22ft long at 10 ft away from the house, since the raised section follows the contour of the "chamfer" on the smaller 15'x10' section. Make sense?
I'll try to attach a sketch if I can figure out how.
The section at the door only has a 4"x4" "joist" at the shallow end for a face board and that 4"x4" clears the ground by only 1.5". It gradually gets higher at the other end so that down there a 2x6 clears the ground by about 8".
The step up, larger section, will obviously be 7.5" higher, at its shallow end and gets some higher from there. Never high enough to need a hand rail so I'm only doing benches on the perimeter.
Off of the large section, on the far opposite corner from where the door is, I'm "chamfering" that off as well and there will be a gazebo pushed up against that corner such that you walk right into it off the deck there. It's the nice composite material and fully screened. It came with this house. The smaller section is sitting on about 20 concrete blocks with 4"x4" "posts". The tallest post there is only about 8inches tall or less. The large section will also use blocks and posts but additionally will have about 6 posts will be dug down and have concrete poured around em for extra stability. its a freestanding deck, not attached to the house.
I'm building the whole thing out of standard pressure treated pine lumber as this is not my dream house, and I'll prob be here less than 7 years.
I will be stain/sealing it so I'd love suggestions there. I've read LOTS of opinons on what to use. One Time Wood, TWP, Cabot, Sikken, Olympic Max, and others. I'm def leaning toward something semi transparent, or even less.."toned" as its called and something oil based that soaks in. Not a top coater. I'll buy at the big box store, or order online, if I just knew what to get. I need to decide because I hope to be ready to seal it by next week.
I love a rich light red/cedar color, but I've read to go as light as I can stand it, because it'll get darker over the years as more layers are added.
Also, the gazebo has a grey deck, and a light creme colored framing so it sort of needs to match it, but I do NOT want a grey deck.
UPDATE on Sealer: I'm leaning toward "One Time Wood" at this point because I'm finding positive comments from anyone who has used it and had it fr several years.
Suggestions, ideas, and thoughts welcome!!
Deck Site:
Sunroom is from the middle to the right in this pic.
Deck will go all the way across the back of that fireplace.
Gazebe I'm tying into the deck:
Deck Plan:
Thanks
DECK:
Deck Site:
Deck Plan:
