1 - 2 of 2 Posts
Concrete & Masonry
Ideally, you would give it 2-3 days at least, and even longer if you're needing to drill anchorments close to the edge of the slab. Even at a few weeks the slab will still be easy to scratch & mar though if you are abusive, drop a hammer off of a ladder, etc...
As for loading the slab with the weight of the wood framing, it isn't an issue, as the concrete will gain strength faster than you can frame.
1 - 2 of 2 Posts
