Hi,
I've got a Bryant 373lav furnace that is giving me error code 31. When it runs, it blows air but does not produce heat.
If I reset the limit switches it will produce heat and function normally for about 5 minutes before reverting back to code 31. I repeated this process while resetting one switch at a time, and found the culprit to be the Blocked Vent Safeguard Tube and Switch (Component #9 on page 3 in the manual).
Does anyone have a suggestion on next steps to further diagnose the problem? Could it be that the limit switch is bad, or is it more likely a legitimate vent blockage?
Thanks!
Thanks!
